jacoviii
- Independence Mo
- 255XD
Ok so this last weekend the weather was good for speed runs. I would call this "full power" testing
So on Saturday stage 1 8300rpm 12/18 twins stock cones (no L13). 56mph @ 8000 port / 7600 starboard.. Yes there is slippage cavitation down low hole shot punching it/ fullish throttles , it is quick to recover though but not an issue during wake sports.
On Sunday stage 1plus 8500rpm 12/18 twins stock cones (no L13). 58mph @ 8300 port / 7900 starboard.
Yes different tune. Midrange and top end felt great. It hit the upper 55mph fast. Then felt like 58mph was bam.
Issues.. hole shot ( Drag race style) cavitation. Normal take off / watersports OK. That can be addressed later.
The issue is at 58 boat gets a bit loose but 1%-3% on the ZipWake trim helps. but scrubs speed.
The scarry issue at 58mph the boat starts to wiggle on the last little bit of keel and any wave introduces proposing then One motor is dropping out or cavitation and the boat tries to make a hard Right I say Right but it might be left. I need to star videoing this...
There is no check engine light or warning faults. hopefully not a temp or knock issue.
So I believe that during the proposing a pump ingests air. It is hard to watch the RPMs to see how the motor is reacting at that time You know with the boat trying to hard turn it's self at the upper 50s. After this a slow to near stop than rev each motor and take off and go again.
- Aug 02 3:00 pm
- 77 deg F
- 60%
- 29.15 Hg
- 62 deg F
- 85.5
- 10 mph
- SE (97)
- 92.529 % AD
- 2634 ft. DA
- Aug 03 1:00 pm
- 72 deg F
- 66%
- 29.03 Hg
- 60 deg F
- 79.8
- 10 mph
- SE (121)
- 93.137 %
- 2414 ft.
