Totally off topic, but do you any good sales people at that dealer you would recommend working with. They have some used boats I'm looking at.as of this morning the boat is in a custody of Saint Charles Boat and Motor,
Jerry is the goto guy for sure. He runs the service dept day to day, but also sells (sold me mine). And, I believe he does all of the new customer orientation after the sale.Totally off topic, but do you any good sales people at that dealer you would recommend working with. They have some used boats I'm looking at.
Totally agree with @BigAbe75. Solid team.Totally off topic, but do you any good sales people at that dealer you would recommend working with. They have some used boats I'm looking at.
Did u use Salt away a few times after being in salt water and leave it in the engine block? Salt away is an acid, acid eats aluminum I’m wondering if when people leave Salt away in the cooling passages whether it’s doing more damage and actually eating the aluminum away?
2+2=4 just saying...
I have been using salt away, actually, once in a while even in fresh water - for example when I change oil, on a hose. I have considered its potential corrosive effects and conclusion is those would be minor to nonexistent in contact with aluminum alloy. The active ingredient is sulfamic acid - which I also have used in home brewing equipment, a standard cleaner there, where it acts as a mild ionic detergent. Sea water is way harsher.Did u use Salt away a few times after being in salt water and leave it in the engine block? Salt away is an acid, acid eats aluminum I’m wondering if when people leave Salt away in the cooling passages whether it’s doing more damage and actually eating the aluminum away?
I bought @BigAbe75 's trade in from Terry. He was nice to work with and low pressure. Almost too low pressure, I had to keep the pressure on them to get the boat ready for me in a timely manor. Jerry was super helpful even after the sale. He made sure to make time for me when I had questions after the sale. If I could go back I would rather work with Jerry. He's more 'matter of fact'.Totally off topic, but do you any good sales people at that dealer you would recommend working with. They have some used boats I'm looking at.
Honestly, I kind of hope it’s something stupid that I did which could be avoidable. For example if oil cooler is cracked because water froze in there, I would know what to do in the future.
Great points!The water should drain out to the lower portion of the motor and the exhaust. When you checked the oil was it much higher on the dip stick ? Did you notice the engine running rough . I hope its something simple but to shine some light on the situation my friend had the exhaust manifold failure. Ingested salt water twice into the oil the local mechanic wanted to tear down the motor and rebuild $$$ he changed the manifold didn't go for the rebuild and it had no noticeable impact on the motor I think he has put over 80hrs since the issue. This was the MR1 that revs to 10200 rpm.
One more way that water could make it to the oil could be be from loading ballast, I know there was some chatter on this a while back but these motors sit very low in the boat there is a water lock but the rocking could potentially get water up to the same point were the manifold breached. Not likely but there is potential. I'm not even sure how the cylinder doesn't hydro lock from the hole in the exhaust manifold the water gets past the rings and into the oil when the exhaust manifold is breached. Hoping for the simplest solution to your issue
Great points!
So - if it indeed were an exhaust manifold crack - pressure test would show it, I guess? I’m not sure how that part of testing works.
That's what I was afraid you would say.Leak down test is what they are most likely going to do this will not show the exhaust manifold issue, visual inspection will be needed for that. The leak down test could show a if the cylinder head is cracked.
Well, I'm traveling and can;t visit with them to check on this right now, and I wouldn't venture to start giving them advice over the phone.Swatski, so sorry to hear about all of this.
One thing I took note of in the video you linked above was the comment that the head bolts on one side were loose. Putting aside for a moment how they got that way, if engine compression is pushing against a head where the bolts on one side have come loose, I can certainly imagine that tweaking the head enough to crack it at the bolts which are still properly torqued. Aluminum is very brittle, as you know, and would not tolerate any amount of twisting without relieving via cracking. Understanding that our HO engines are not boosted, there's still a fair amount of pressure pushing against the underside of the head.
Wondering if maybe, as a first order of business, the dealer might check the torque of all the head bolts on your engine to see if any are loose. If they are, we should all be running out to our boats with a torque wrench immediately.
Now I'm wondering how they would get that way as reported in the video. Quality head bolts shouldn't stretch with the kinds of pressures our engines, even the boosted ones, are generating. . . .
Jeff
Calls for patience and restrain from jumping to conclusions are warranted, I might have misheard parts of it. Basically, the oil looked poor and after 4(?) changes was still not clear.I agree let's get the final story before we feel guilty
4 oil changes and still not right?? Note to self, if ever get milkshake oil spend the extra 30 minutes and pull the bottom plug for a complete oil drain
Only because i trust you and your diligence, any chance of sabotage-vandals at your marina? We've seen many milkshake engines never heard of tar like oil with the milkshake
A good lessen for everyone to take five minutes and check your oil every outing to help identify and mitigate any issues
