I have the air filter and ribbon delete spacer being shipped right now. I am absolutely not putting this thing back together if i have any concerns about plastic gaskets getting sucked back in. That sounds horrifying.
My understanding is:
1. If Riva Kit then Rubber gasket ribbon holder thing is OK (as per somewhat misleading Riva Directions PDF).
2. If
NO Riva Kit then make sure the rubber gasket is removed... You don't want that thing sucked into your cylinder heads.
I just want to make sure I totally understand... the issue
@Irvs had sound horrible with that gasket... .
Also, my plan is to put the ribbon back in if I need warranty work, I have 15 hours on the boat and don't expect any. (Should be easy to put it in/out on the 190 as I don't have a manifold or supercharger to work around).
Thanks everyone.
