MattFX4
- Marietta, GA
- Other
- Other
I've done 6v batteries and will not do again. It's not double capacity. You can't add the ah like with 12v because they are in series. If one dies, your done. When my boat batteries die, they're getting agm for sure. The last thing I want to do I'd have to top off the water 4x a year at minimum. Spilling battery acid on carpet is less than ideal, even with the mandatory battery filler (well worth $12) you'll spill sometime.
There is no way to know how much your stereo pulls unless you play some typical music, at typical volume, and measure the amps using a current shunt. Adding peak watts for all channels will represent driving the speakers at max volume continuously during the largest bass hit. You would need a frequency generator to play a ~40hz tone at full volume to even come close to using peek watts.
That's true. Two 150AH 6 volts wired in series does not double the capacity to 300AH. I remember learning this when buying batteries for my golf cart.
