Bill D
- Prairieville, LA
- Limited S
@jeremy0011 - I'm sure I can do it, where can I get the brass bushing needed?
After pressing it in you will need to run the proper drill bit and 10-32 tap through it. The bushing is made for plastic parts and it will deform when pressed into aluminum but once taped it works perfectly.
Super late to the party.After pressing it in you will need to run the proper drill bit and 10-32 tap through it. The bushing is made for plastic parts and it will deform when pressed into aluminum but once taped it works perfectly.
Do you have any tow point adapters left? With or w/o the navisafe included.
Thanks
Wow just saw this, what a mod. Would like to order the navisafe option. Please let me know how to pay.
Thanks
Trying to find something like this which would also work. The image is from a Titan sight no longer functional.
