Bill D
- Prairieville, LA
- Limited S
Yeah, with no fire the plugs should still look new. I believe the lanyard is the only safety that will run the starter but not allow the boat to start. Pretty sure the neutral switch and clean out hatch will not let the boat even try.
If you have a multimeter you can ohm the switch out. You should see 0.1 ohms when the lanyard is in and OL or infinity when the lanyard is out.
