So here is a semi-quick write up on my DVSR mod. I spliced into the port side fuel pump for my "run-hot" wire so that the DVSR is only energized when the engines are running. I looked around quite a bit for splice's and decided on Wago. They were a bit more expensive but are high quality and lever activated so easy to use. Since I didn't know what gauge wire was used for the fuel pump these connectors provide some flexibility as they accept 12-24 gauge and they do not have to all be the same gauge. I also bought some of the Wago gel filled waterproof splice housings for the splice into the fuel pump since it is under the floor and I wanted to be sure that it stays dry.
Inline splice for DVSR to fuel pump wire:
Three way splice for tapping into fuel pump hot:
Waterproof gel box for fuel pump splice connector:
Removed the DVSR assembly from battery compartment wall - five of the fasteners screwed into the wall and one was a long bolt with a nut on the end. There is a cover plate on the back of each of the four modules that need to be removed - they are just pressed on. I then straightened the red wire (looks more like pink) which can be seen in the lower left corner:
Based on the info that I've seen in this thread, the side of the wire that does not have power when the DVSR is energized is the one farthest away from the post with the red paint on it. I cut the wire in the middle and then attached a Wago splice to each wire just in case I picked the wrong one. I used the wire that is coming out of the bottom of the DVSR housing as the side that I will run to the fuel pump hot. The wire that is coming out of the side will only be used if I chose the wrong side which will make it easy to switch over. The post with the red paint can be seen just above the wire that is running out of the side of the DVSR housing:
Decided to use blue wire (I think it was 16 gauge) as it's consistent with the color that Yamaha uses for "hot" wires. I cut off a piece long enough to make it back to the fuel pump and connected it to the other end of the Wago splice:
Put the four cover plates back on and remounted the DVSR assembly.
Removed the floor panel that provides access to the gas tank and fuel pumps:
The port side fuel pump is on the right:
Disconnected the plug by pressing the right side of the harness - the release latch (red arrow) was stiff so I used a pliers to press on it which worked like a charm. I then stripped away the electrical tape and cut back the flexible wire channel that protects the two wires so I would have enough room for the splice.
Ran the blue wire back towards the rear of the battery compartment where a large hose pops through into the engine compartment, ran it along the top/rear of the engine compartment, and pulled it through the same opening as the fuel pump wires:
Cut the blue fuel pump wire - sorry it's blurry:
Stripped the insulation on both ends and placed them into the Wago splice connector:
Stripped the insulation back from the DVSR wire and placed it in the third position of the splice connector:
Placed the Wago connector inside the waterproof gel box and sealed it up:
I put the floor panel back on and tidied up the wiring with cable ties. Turned the start and house battery switches on and no red light on the DVSR. Started the engines and red light on DVSR came on so I chose the correct DVSR wire to connect to.
I hope this is helpful for those that want to do the same procedure even with some of the blurry photos.
I hate projects and am glad this one is over.
