- Florida
- Other
- Other
Honestly all these things have been discussed many times, not to upset anyone but there is a reason people buy lifts and float on docks, it is because leaving a boat in salt water is a really bad idea. Notice I said BOAT not just a jet boat.
Aside from the corrosion factors, there is the sea life that will start growing on the boat and in any water passages that are submerged. The areas like the pump and intake tunnels are inviting places for barnacles to reside. The cooler water may take a bit longer for those things to begin to grow but in the Gulf of mexico I would begin noticing it withing 5 or 6 days. Any boat will take a beating if you leave it docked in salt water. Using it in salt water is a different situation, zinc anodes help, flushing the engines really well helps.
I now use car wash soap as it has a liquid wax in it that leaves a film inside the water passages, I believe this helps to prevent things from attaching to the walls of the passages.
Using really good hose clamps with cable tie backups will also help.
White lithium grease sprayed all over the engine and pump exterior helps as it forms a really good barrier that is not really visible so it does not look like someone vandalized your boat.
Extra ground wires from the engine to the battery are also a good idea as the grounds go bad first.
Put it on a trailer or a float on dock or a lift unless you want to be dealing with the negative side effects of constant exposure to salt water, just be glad it is small enough to be able to put it on a float on dock , lift, or to be able to trailer it.
