Mainah
- Chapin, SC
- Limited S
I am happy to help but not being a e-series owner makes it a bit more difficult. I need someone to remove the solar panel positive wire behind the dvsr and monitor volatge readings over differnt amounts of sunlight hitting the solar panels. The purpose is to verify that it has a charge controller that will not output less than 12 volts. This will need to be one of the triggers to combine but relays typically accept far less juice to trigger.
