- Raleigh, NC 27614
- 242X E-Series
I Like it...I would suggest a box end wrench slipped over the shaft to the impeller nut.....really prevents slipping and makes it feel more secure with the torque required....especially if you end up with a 4 foot cheater bar.This how I did it without a vise.View attachment 47112
the impeller shaft can only be separated from the duct (the part with bearings) with a press ...disassembling this portion is not necessary for impeller replacement.
Ya Bruce I have to replace the housing bearing, because water is dripping from where the housing meets the stern of the boat.@su laxplayer21, are you replacing the "housing bearing" that seals the engine compartment or the bearing that holds the shaft at the back of the pump. If it is the bearing at the back this should help https://jetboaters.net/threads/chan...-and-switching-to-oil-bath-lubrication.10155/
Julian, I am going to attempt this job Monday. Normally, without trouble, how log would you estimate this job to take per engine?I think you could have saved yourself some work by only removing the outer 4 bolts on the pump, not the ones that attach it to the transom. This would have saved you from having to pry the parts apart on the floor on their own with a hammer (doing it on the boat is easier....although some have had some interesting challenges getting it apart on the boat).
Totally depends on if your shaft is stuck or not and how much effort it takes to unstick it.Julian, I am going to attempt this job Monday. Normally, without trouble, how log would you estimate this job to take per engine?
I starter to take my impeller off, got it broken free and did a couple of (very hard) 1/2 turns with the extension. But, it doesn't seem to be getting any easier as I'm taking it off, maybe even a bit harder....I'm definitely going the right way, exactly the same direction as above. Is that normal?Totally depends on if your shaft is stuck or not and how much effort it takes to unstick it.
But unstuck it will take you 10-15 minutes per pump.
Make sure you have a nice sold rubber mallet or hammer and wood block. Helps to get the pump separated when stuck. Then have a big screw driver or pry tool to put between the edges of the pump to gently separate them.
Thanks. That's what I've been doing....giving it a bit of a break, couple more turns, backwards a bit, more PB, etc....I guess I'll just have to stick with it.It's unusual but if it has been in place for many years and never removed, and there is a little rust in there, it could be expected. No harm in going back and forth a few turns while you spray with lubricant to help it along.
Now I'm really not sure. It will barely budge either way and when I CAN get it to move a little its with a ton of force and it makes like horrible sound.It's unusual but if it has been in place for many years and never removed, and there is a little rust in there, it could be expected. No harm in going back and forth a few turns while you spray with lubricant to help it along.
I don't have a torch....I could buy one I suppose. What could possibly go wrongCan you put some heat to it? That seemed to soften mine when it was really tight (and broke the vise)
