@Robby, Does it turn over and "RUN" and if it just means no gauges, your okay as far as driving the boat??? I am sure at this point it is up on a trailer and sorry to hear about the trouble.
I think you are correct.
Now I need to figure this out... I kind of love these "stranded" threads - always eye opening (for the semi-ignorant owner, like myself, lol).
Thank you for the info, and re-posting those good/informative threads!
Even with the ECU out, there should still be power to the gauges, I would think. Then you should be getting a COM error, not blank gauges. Sounds to me like your bus is disconnected somewhere, probably completely, that is preventing power to the gauges (and preventing the engines from firing up). Anything happen before the failure of note? Change the spark plugs or add an accessory or anything? Put in new batteries? Anything?
I will have to try it again tomorrow and see if the fuel pump is working. My battery went dead and we was jumping it off when it happened. Is the only fuses located in the rear of the engine compartment
Voltmeter on the battery while cranking will confirm, or just remove battery and get it charged at auto parts store, usually for free.
Edit: but, if the engine spins with gusto... Not sure low voltage would be it.... Most demanding task is making engine turn. I'm not sure this is it, but it would be easy and cheap.
So still trouble shooting and I ended up pulling the main relay to check it and it was good. It has a good power source from the battery but is not getting a signal source to trip the relay. The dealer ship is check the wiring diagram to see what feeds that and if it’s the computer i will have to replace it. It runs fine once you jump the power on the relay with a jumper wire. I think more then likely the jumper cables got connected backwards and it fried that circuit in the ecu.
just traced that relay to the computer so it must I have fried just that one circuit because everything else works and runs when I bypass that relay with a jumper wire on the circuit side. Looks like a 1000 dollars it is!!!
I thought about running the power straight from the ignition because there is a spare power wire on it but I am not sure if it would effect anything else as far as safety shutoffs for the engine. Just not sure if it is worth taking a chance.
