Seems odd that neutral "creep" is excepted as normal and having to turn off the engine is somewhat overkill, as you're then faced with having to restart the jets if you do need to back off or advance if a strong wind.
Is adjusting the idle something that requires a trip to the shop?
Adjust the reverse buckets to get better neutral but remember the jet pump has no true reverse or neutral all that is created with the reverse buckets redirecting the forward thrust so the only real neutral would be to turn off the engines not the most practical thing to do I know my mega fang plus capture more of the reverse thrust so that can reduce the forward push when in neutral. This post comes to mind https://jetboaters.net/search/48025/?q=fangs+true+neutral&o=relevance
Nothing is static in the water especially the ocean given winds and tides whether you have a stern drive or a jet. Granted, stern drives have a better command of neutral than jets whereas jets have a compromise neutral. But stern drives derive neutral at the added expense, weight and maintenance of a transmission. Take your pick.
on that note remember a jet has NO transmission and that can work in your favor. With a jet you can work the throttle levers in forward and reverse rapidly since there is no transmission it is very smooth transition and you can keep a boat in one place by learning that trick you can also walk the boat one inch at a time either forward or reverse by manipulating the throttle lever or levers and with twin boats you can manipulate the throttle levers one in forward and one in reverse to rotate the boat in place, so there is an up side to the situation.
