"txav8r said...Flooding the engine compartment does not ruin the engine. Starting and running a flooded engine will ruin it. Yamaha does not warranty water ingestion because it is almost always operator error in some way. If you have a plug blowout at speed, you can expect a flooded engine compartment. That is not catastrophic. If you ever flood an engine compartment, you need to make sure you didn't ingest water BEFORE you run engines again. This is a tough situation.
"Big Shasta said...I disagree, A flooded engine compartment can cause water ingestion and if the engine us running at a high enough RPM and the water ingestion is enough of a volume of water, the momentum could easily cause hydro lock before the pistons came to a stop.
We can agree to disagree then Ken. If water is high enough in the engine compartment to be ingested, you are going to be bogged down and not running well at all, combined with the plug that has blown, the signs of something wrong are waving red flags big time. This does not happen so fast you have water instantly above the air cleaners. IMHO, you would have to continue to run the engine well beyond when there were big clues to shut down. If this happens so fast and incideous as your suggesting here, how would a bilge alarm help you? It would just confirm what you already know, that you have a problem. I am not suggesting for one minute that a bilge alarm isn't a good idea. Even at WOT, at 52 mph, if a plug blows and even wedges in the clean out tube neck and doesn't shut down the engine, the loss of thrust and the increase in water is going to give you big clues. And long before the engine hydrolocks, the water in the air cleaner will disturb the air/fuel ratio so much that the engine will DIE. So I would argue that if you take on water due to a high speed plug blowout, that the engine will die before it actually does damage. And that it is operator error, of starting an engine that has ingested water and become hydrolocked. And that is the way Yamaha views it too.
