Greg M
- Oklahoma
- Limited S
im on my third Yamaha boat and have a friend that's on his 4th. between the two of us, there has literally been 1 time a plug has blown out.... and it was because a friend of mine put them in and didn't know what he was doing.... ie my fault (I always remove my plugs when leaving the lake, put boat in, forgot to put them back in)
Look, if you dig into the Failed Plug/Blew Out threads and start asking questions, two things seem to pop up every time.... they either had them out and didn't put them in right but "know I had them in right" (its never the guy in the mirror at fault and its not hard to think they are in when they aren't, I'll concede that) or they never had them out, they froze up from neglect, they went thru hell to get one or both out to clear something, and then put it/them back in and they had an issue. The issue in that case was neglect.
Get some clear silicone grease. Remove your clean out plugs. Run some grease around the rubber lip. Makes them sliding in fully extremely easy.
See all that gunk and algea and mud and lake residue on your plugs? exactly, clean them off (or keep them clean in the first place), spray them down with silicone spray. Do the above, and make sure they are seated.
Lastly remember, youre dealing with tight tolerances, this isn't a brute force procedure and if youre straining to put a plug in you are doing it wrong! Its a finesse installation! Do it right with a plug that isn't junked up, they seat right in.
Its a moving part, it requires occasional maintenance. You clean the outside, you lube the bearings, you change the oil. Add 5 minutes to your todo list once a month and it should be problem solved, or problem never is created as far as plugs are concerned.
