Speedling
- Cedar Lake, IN
- SS
So how do these straps work????Installing my own snaps! Was a little scared since i had never done before but now i think we got this.
Making straps so i don't have snaps on the back of my boat for the cockpit cover.
Well, the idea is to have the snaps snap onto the snap on cover snaps. They are put to the inside of a looped end, which means the snap isn't rubbing against the boat at all, just the fabric.So how do these straps work????
Looser than you think and would get wind whipped all over the back step while driving for sure.Why not just put snaps along the edge of the first step and then have loose fabric laying over the last part of the swim deck? It probably wouldn't be that loose with the arc of the step holding it in place?
Just tied up the straps to the back of the boat instead of doing any drilling. I think i will try it all out during the Cumberland and Shelbyville trip and see how it does.@Speedling
Loose without the poles would be okay because you won't be driving. So I would put the snaps just under the rub rail. Out of the way and should never be hot in sun, and on back of leg, because of lake water. Still tight while trailering. My two cents.
I tried figuring out the bow in a similar fashion but grew impatient and drilled the holes. The back platform is really the only spot where the snaps are invasive.That's a good idea. If it works I would stick with that. Less of the snap holes, the better. I like bow and cockpit covers but not the snaps required.
That lit up building looks very much like Frost Tower in Austin.
