AndyD
Jetboaters Commander
- Wake Forest, NC
- 242 Limited S E-Series
Nope. Reject. Never. Ain't gonna eat them things.
You're missing out on some good food. But that's okay, more head sucking deliciousness for me.Nope. Reject. Never. Ain't gonna eat them things.
The whole thing is moldy. Soft from the table base to the rear. Where my family is 90% the time when not in the water.@Speedling Are those water leak stain marks around the table base? I will definetely be pulling mine as soon as it warms up. Meant to last fall after I had all that water in the ski locker drain, but decided to wait til spring cleaning.
The heads on remaining bolts are off. I don't have a stainless welder setup. Grinding a flat spot may work to get a wrench on them.@Speedling do you access to a welder to weld a hex bolt to the top and take off with a large breaker bar? Plus the heat may help from tacking the nut on? Make sure to lay a weld blanket or something down and area ventilated with the fuel tank right there.
Or else you could grind two flat spots for a better grip? I know you probably tried but tap on the heads down and also try to tighten as it may loosen up some and give you play to back off. Hope something works for you.
Lol i like that idea of siliconing the heads back on! But with 8 of them broke off that may not be good for keeping the floor in place so SOME of them need to come out yet.I had to drill several of mine out also. I put all new stainless, allen head bolts back in . On the couple that I couldn't remove I just silicone the heads that snapped off back in place to give it an appearance of being installed.
Nuts are embedded in the glass.@Speedling First thing that comes to mind is heat from a torch, but with the proximity of the fuel tank and the fact they are stuck in a fastener imbedded in fiberglass, that could be tricky. Not having mine off yet, how are the nuts/keepers attached to the floor? Glassed in? Could they be removed and replaced with new then reglassed or epoxied back into position? Grinding/cutting off flat drilling and retapping can be difficult with a S.S. fastener. Is there enough bolt sticking up, and are the threads good to put a double hex nut on them and try to crack it off that way? Good Luck.
These werent wild birds, we went to a hunt club. They were flight pen raised birds that were released an hour or so before we started hunting. It was great experience for the dogs. And dont let the picture fool you, quite a few of them got away from us. The final count was 10 pheasants and 4 quail.@T. Turner I hunted pheasants for years and never got what you guys got in one day. I stopped hunting because I grew tired of humiliating taunts of the creatures I hunted.
