Ronnie
- SF Bay Area
- Limited S
Whatever happened to drilling a hole on the ice and sitting on a bucket lol. My uncle has a custom shanty with a generator, wood burning stove, and Direct TV. I do agree getting out of the wind makes a world of difference.A test set up of our Clam ice fishing shanty. It’s a nice little pop up.
That’s one hell of a plan!Boat was covered just in time and I got the motorcycle inside the house. Now to plan my next adventure: Bogota, Colombia -> Medellin, Colombia -> Sao Paulo -> Rio de Janeiro. All one way tickets. Ideally I won't come back to USA until April or May. I hope everything works out ?
Worked on putting the sled engine together. Just need to add coolant, gas and test run it before I put the hood back on.
Just waiting on the 5-8” of snow and blizzard conditions to test it out later in the week. Figured you’d come buy it after that. ?Wait a minute! You sold the plow but are keeping the sled? Not enough white stuff in Alabama for that either, unless you take up watercross. Your gonna have too much fun, lol.
He's had a shop replace a couple things. He said they wanted like $750 to diagnose any further and he's on visit #5 for the issue. I want to say he told me the actuators are working, and the controls are working, but nothing changes. I had a '99 S10 that a blend door that physically broke with similar symptoms. Was a junkyard part for $15 and a weekend worth of pulling the dash apart to replace/repair it. Figure this is likely something similar. He's flustered at it because he lives in mid-Illinois and can't drive to work without defrost.The heat/AC blend door actuator above the gas pedal is most likely the diverter problem. Same thing happened on my 06 2500.
My ‘03 Chevy avalanche developed a similar problem, per you tube I just removed the related fuse for a few minutes to reset the system. This worked about half the time but I had to do it almost every time I used the climate control system. I eventually gave up as the truck was otherwise nickel and diming me with other issues, ended up selling it as is for a lot less than blue book. Chevy, never again unless it’s a Vette.The heat/AC blend door actuator above the gas pedal is most likely the diverter problem. Same thing happened on my 06 2500.
