2kwik4u
- Buffalo, NY
Sounds like a great shop. ? Are you going to be storing the Yamaha inside as well.Started another project, even though i already ordered 8 grand worth of Trex decking to replace all my disgusting wood thats looks like crap and spots are rotting after only 7 years. All the Trex is being delivered Tuesday. But will be on hold till i clear this area of my property.
Putting a 40x61 shop up. The guy that is filling, grading and putting in the culvert and driveway is ready to go. Me and Jeannine are clearing the brush and smaller trees to save some money.
Cant wait to have my dream garage up.
Plan is to work on bikes, jetskis, and outboards with the occasional vehicle. There will be a 10000lb car lift and 3 motorcycle lifts, tire machine and balancer etc.
Big plans for the future. Getting away from working for someone and work for myself
View attachment 193436View attachment 193437
It will fit for sure without lowering the tower but it will stay on the pad its currently on. If a bad storm comes it will go inside for sure.Sounds like a great shop. ? Are you going to be storing the Yamaha inside as well.
Jim
Getting my boat inside was my primary reason for building my second garage. Make that thing bigger! Looks like you’ve got the space.It will fit for sure without lowering the tower but it will stay on the pad its currently on. If a bad storm comes it will go inside for sure.
All my other yamahas and other toys will be inside it. 2 4wheelers, 3 motorcycles and the jetskis
Its primary use is a workshop, not storage so it wont get filled up.Getting my boat inside was my primary reason for building my second garage. Make that thing bigger! Looks like you’ve got the space.
40x60 is huge but they always fill up.
Found this in my iCloud. This was me back in 2019 in OBX jet-boarding. Highest I went was 30ft above the water, and it hurts when you lose your balance.
- YouTube
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.youtube.com
35 with 20mph north wind, cleared some space in the garage to reset the valve lash on the riding lawnmower, briggs has to have found a better way, third time in six yearsView attachment 193468
In my experience racing fourstroke dirt bikes off road diminishing valve lash (I’m assuming the valve lash is getting tight) has a lot to do with very fine grit getting into the inlet tract. The obvious is to make sure the main air filter is clean and seated properly, a little grease on the sealing surface helps. The other thing that made a big difference for me was to put some kind of filter on the carburetor vent tubes. Just a simple piece of a cotton rag over them helps, or if you can rig them up to pull through a fuel filter ovsmall oiled K&N crankcase breather even better.
Once you get the hang of it and understanding your balance its a blast. I would recommend it to anyone who hasn't tried it.Right now I will have to leave this to my dreams and or imagination However it sure does look lie fun
I'm a junior grade mechanic so even my terminology might be incorrect,
my rocker arms get loose causing excessive gap/loose fit,
The mower doesn't like to start, like it's got a bad battery or starter, very slow to no crank,
supposedly their is a lobe on the cam that it supposed to stop the engine at no compression so that the starting crank happens easier (if I crank it with no spark plugs, it spins fast), it's possible that lobe broke off or I can't adjust valves because I set them going by the manual but it still has issues,
Horseshoe crab?
