- Northern Vermont Lake Champlain
- Other
- Other
- Other
A warm 83 degrees at 7:30 this morning on the eastern shore of Alabama. .63 degrees at 6:30 this morning on the Eastern Shore of Maryland.
I’m getting used to the temps quickly. It’s hot but not unbearably any more. Just like the extreme cold, you learn how to deal with it.All y’all with temps between 95°-121°f, do you ever leave air conditioning? A nice outdoor working temp of 56°f this morning.
2,zWhat a can of Truley costs at concert venue (Shoreline Amphitheater) here in Mountain View, CA. Thankfully, neither my wife nor I were that thirsty.
We went cheap and bought cans of Soda instead, I thought it was strange that they were required to open the cans before handing them to us.
View attachment 206790View attachment 206791
Ok, so I posted a thread last month on the missing bottom jet pump nozzle bolt that fell out while in the water and locked my rudder behind me CJS fin causing me to loose right hand steering until I could asses the issue and fix it. Today while on the Manatee River, my top bolt that holds the nozzle to the pump fell out. Thankfully I couldn’t tell until I finished flushing and washing the boat and spraying my rust/corrosion spray in the steering cable sheath and noticed the nozzle seemed loose. Further inspection showed the bold completely missing. Since I had this problem before, I bought a couple extra bolts and had them in the garage. When I ran the new bolt through the nozzle to the pump housing and manually moved the nozzle left to right, I could see the bolt spinning back out. As an engineer, when a company launches a product they do a DFMEA and a PFMEA to find failures within the process or design. Why did they not just through bolt the nozzle to the pump and put a nylon nut on the back side to prevent this since it is already through tapped and can be used as a pin?
below are of the rudder stuck behind my steering fin when the bottom bolt came out.
View attachment 206852View attachment 206853
This pic is only the missing top bolt.
The steering installation has nothing to do with the nozzle bolts, in past models the bottom bolt had to be removed and reinstalled and both of those bolts need a good thread lock on them to keep them from coming loose also the factory has stainless steel standoffs that are held tight against the inner nozzle to create a void for the nozzle to turn on otherwise the bolt would stop the nozzle from turning. If anyone ever removes either of those 2 bolts on a stock boat and does not use thread lock on them they WILL come loose . The 2019 and newer super ultimate systems do not use the top or bottom bolt to attach the nozzle So they were not used to accomplish the installation. This has nothing to do with my system it has to do with the bolts not being properly thread locked .
Any time you remove the nozzle bolts on these boats for any reason with or without steering added you MUST use thread lock compound and let it cure before using the boat I go into great detail regarding this as I said when my system uses a bottom nozzle bolt . so any one who removes their nozzle for any reason must add thread lock to the bolts. I also have alternate bolt sets for people who stripped their thread on the inside nozzle so they don't have an issue He may need to order the nozzle collars I suspect he did not have those in the nozzle when he said the bolts turned when he moved the nozzles side to side because they are inside the collar and the nozzle is loose with up and down clearance just go grab a nozzle and move it up and down on the trailer. Usually any issues with the bolt on the bottom happens pretty quick after someone removed it and did not install it properly . This is the first time I have ever ever seen any top bolt come loose so I believe he must have worked on the nozzle recently and did not know Yamaha requires the thread lock on those.@Cobra Jet Steering LLC I wasn't inferring it was your system, Jeff. But since you know all of the parts on all the nozzles and steering on our boats, was hoping you could shed some light on it. Sounds like @Thermobrett you need to use some thread lock.
Our 10 year old $800. dyson vacuum stopped working, only half the brush would turn,
my daughter and I took it apart and were able to find the problem,
broken gear spindle, google says it's not an uncommon issue,
new one is on order
View attachment 207009View attachment 207010
