@toddaltpeter Thank you, I am writing this all down. I am anything but an electrician, so we will see how it goes. A side question, if I run two LED strips under the seating pads, can I still connect to the courtesy switch with them too?
You should be fine. LED's don't draw very much power. I'm not sure what the fuse amperage is that protects the courtesy lights. I would be surprised if it was a problem.
How much better is the M series amps vs the MX on the JL brand? Wondering if better to go with two MX 280/4 or one M600/6? Priced new is not much different. M is just a bit more
This is probably a super dumb question. But what's the best way to connect the speakers? Simple spade terminals? How are they protected from the elements?
My 2 cents, 14AWG for normal speakers is way over kill.... I just rewired my whole boat and put JL M6 7.7 speakers in and ran 16AWG which was still probably a little over the top. For my M6 10 woofer I ran 14AWG. No issues
As far as wire strippers go really any of the ones off amazon will work, if you want a recommendation try These. I have a set that's probably 15 years old that is not near as good as those and works great.
I also bought two of those kits, only used the things for the power wire though. Junked the RCA's and speaker wire, for me the RCA's were too long and I was unsure of the quality.
