@tabbibus One of the benefits of bus bars are that its simpler to connect and disconnect the batteries. I have a ground bus bar that all the negatives in my boat connect to, then I have ONE wire from the bus bar to each battery. Super simple.
I have a Positive fuse block too. One wire from the house battery to the fuse block, then everything is fused there and connects to the rest of the boat. This also makes it easier if you want to add things to the boat later (like USB charge ports, marine radio, fume detector, bilge alarm, amps, etc).
The "magic" at the speaker can be made easier with dual spade adapters. Not sure if
these are the right size (they are electrical piggy back - not speaker ones) - but I have to assume they make speaker ones too.
This pack give you an assortment of sized piggybacks.
