Pullen724
- Conroe, Tx
- Limited S
Ive fill the bilge with water and cant see any water leaking on the outside.
Ive tried to completely dry it out and narrow down where water is coming from but it seems to be from somewhere that I cant see through the few openings on boat.
I plugged the anchor locker drain and the drain for the stern storage compartment where the clean out plugs are to rule out intrusion there.
There does seem to be water standing on both port and starboard side on the outside of both clean out tubes. There is a small pocket on both sides that I can feel water in but cant see due to the clean out tubes. If these "pockets" are filling up with water from somewhere I cant see, where would it be? It looks like water may spill over out of the pockets and get into bilge.
Dealer says they cant find a leak so it must be fine. I get 20-30 seconds of water draining after a few hour outing with nobody getting in or out of the water.
2016 242 Limited S.
Ive searched all the threads I can find on this topic and gone through all the checklists of common areas.
Anyone found a secret troubled leak spot that is hard to locate?
Thanks
2016 242 Limited S.
Thanks
