- Royal, AR
- SX
@sailorkane, Julian’s rebuild video in this thread should help you understand how the plug works.
Are you certain that you do not have the twist plugs? I am uncertain if they had a locking mechanism.
Pushing the unlock button should release the dogs. I have never tried to look to see if they have unlocked. You may be able to check with a flashlight. Disassembling the plugs in place might be an option for you.
I would tap the top of the plug downward with a long brass drift or even a 2x4 to see if the dogs respond. Then ice up the plugs and see if they will pull.
