- Corinth, TX (DFW)
I would source a new plug before you destroy that one, last I remember they are hard to find,
try removing the screws and pull out the top half leaving the bottom half and then you only need the bottom half with gasket in the kit.Good for you. Not very badly stuck, then. On my starboard one, the push button latch was working OK--it did release the locks, but wouldn't come out. I did all the usual things (hammering, ice, pb blaster...) and then had to put a bar over the swim platform and a heavy duty ratchet strap. But I needed a 4x4 for the bar. Anything less would have bent and broken. I bent a putty knife into a curve and hammered it around the edge of the plug to unstick the rubber seal. Finally it popped with a loud "pop". That was the "easy" starboard one. Never did get the port one out; on it the push button latch was frozen; needs to be cut out.
So after nearly 20 years of Yamaha jet boating I finally made the mistake of leaving my plug installed for too long. I left the boat on its lift over the winter and neglected to pull the plugs. Sure enough, they were stuck. Took me about an hour total and I was able to get them out. The single best approach I took was using a long (4 foot long) wooden closet hanging rod (1.5"? wooden dowel) and a hammer. I took the rod and hammered the plug DOWN and at an angle as much as I could on various parts of the top of the plug. This loosens up the crap that is sticking the plug in. Then I used the same rod with a rope loop over it and hooked to the plug as leverage to pull the plugs out. Worked like a charm for me. And yes....the rubber skirts on both plugs are swollen to the point that I didn't even try to force them back in. I just ordered the rebuild kit and will replace them ($45 each).
Yes, I did rebuild them at the start of last season as they were getting harder to remove and re-insert. 2017 was the year they started the new twist in plugs - so I don't have those. This is the first year I've left the boat on the lift throughout winter. I'm going to have to pay much closer attention to my routines to ensure I take care of them better -- I got lazy and paid the price! Fortunately $100 isn't a major hit!And if I remember correctly, you've got the newer push-twist plugs, right? AND didn't you just rebuild them this past season? Ouch! Sounds like the rebuild was a much better sealing plug, which caused this.
The more I read about these plugs, the more I think my plugs aren't sealing properly, or at least aren't sealing very well. With all of the other things I did to remove water from the cleanout tray, I'm not so sure I'm dissatisfied with them not doing their job very well, since I've got such an easy time removing them. I can't recall if I left mine in the boat, so Murphy's law says that I did, and that when I pull the boat out of storage, they'll finally be stuck.
Here's hoping a rebuild kit won't be on backorder for months on end.
Need to release the locks. It appears to me that unscrewing the bottom only releases the bottom part. The top needs to be disassembled to get the stuck locks unstuck. Can disassemble the top without getting to the side of the plug. No access. I purchased a complete replacement plug. Just can't get the old one out.try removing the screws and pull out the top half leaving the bottom half and then you only need the bottom half with gasket in the kit.
If the latches on the side retract when you push the button, you have a chance. If not, no chance. If they retract, get a 4x4, span over the transom area, use strong ratchet strap or jack. I used a putty knife, with end bent to match the curve of the plug and hammered it all around the outside edge.Just wanted to share that yes that thing I was afraid would happen... Happened.
Just wanted to join the stuck plug club thread. I have tapped and sprayed with liquid wrench. I used an air hammer to vibrate all around the plug and unscrewed the 8 screws. The top half is stuck, but I haven't used the jack on just the top half. (I broke the tray when the plug was still screwed together).
Yeah.....NEVER put pressure on the tray. It is far too thin to take ANY pressure.Just wanted to share that yes that thing I was afraid would happen... Happened.
You should be able to patch that crack up without a lot of hassle. In fact, you could probably just leave it, knowing that water coming in there is just going to drop into the bilge anyway.Just wanted to share that yes that thing I was afraid would happen... Happened.
I like this idea. Should be waterproof. I used anti-seize compound on the aluminum tubes. They have the copper colored and the silver colored. I used silver. Not enough experience to know if it worked.Anyone ever use silicone pool lube to coat the plugs and avoid the issue?
