WildCatFan54
Jetboaters Commander
- Lexington , Ky.
- 242 Limited S E-Series
Am I being overly optimistic in trying to simplify the install of this Kenwood KAC-M3004 amp OR hopefully I am reading this correct? I have attached a couple images from the owners manual that came with the amp I received today. First question : Image #1 seems to indicate that a separate "power on wire" is NOT required for this model ? The way I read this only a positive wire from the battery (10 gauge) and a similar 10 gauge ground wire from battery negative post plus the RCA inputs from pre amp output are all that is needed ? I believe Kenwood calls this Auto Signal Sensing. That would leave connection labeled #4 in the second attachment unused ? Secondly : Should I still put an inline fuse on the positive wire from the battery being that the amp has a 30 amp fuse ( #1 on image #2) built in ? I will not be running a sub (at least on this amp) only six Polk MM651UMs , therefore plan to use only 10 gauge wire from the battery compartment to the helm area. Thanks all !
