- Royal, AR
- SX
Okay, so I have a quick question. I am currently running a Kicker 5 Channel amp. It has a designated Sub Woofer channel. Amp seems to be having issues (got wet I believe). If I replace it, do I have to go with another 5 Channel amp? Or will this Kenwood 4 channel work? Or would I need 2 Kenwoods?
Do you have four speakers and a sub? You could run the four speakers in parallel as a 2 ohm load on two channels of this amplifier and use the other two channels for your sub. Depending on how much powers your Kicker produced you may want more wattage than two channels of this Kenwood amp will provide.
