@AZDANSX230HO , the wind loading and snow loading on buildings such as these, are far superior to traditional construction or even metal buildings. A Future Steel (Steel Masters) building is rated for 130mph wind loading, and a 5' snow load.
Thanks for the other options
@itsdgm , I have been considering that. But even those doors are limited width is seems, so having a 28 or 30 door beside the garage door is better I think.
@zipper , yes, I will have flush mounted switch plate and outlets in optimum positions inside the building, planning for lighting and power needs. I also want to consider future needs...if I only knew what they were! lol I am spray foaming the inside, so after, I will run electric runs on foam and behind OSB and in wall recesses, I will be able to flush mount outlets and switch plate. I intend to flush mount even the RV power pedestal.
@DawgDaze , thanks! And howdy!
