Good Day everyone I am looking for some guidance/assitance with my Jetstar 1250.
I believe I have the Suzuki 50HP. My jet drive has the Plate attached to it .
The boat ran pretty well 3 years ago but started to take some water. its been sitting since.
I seem to have narrowed the leak to the Steering Cable Boot. ( where can I get a new one and How do I remove and re-install this? does in install from the inside or is it all external?)
I would try to clean all the crap off of the old boot and see what you have to work with. after taking all the old silicone and paint off i had a real nice boot with no cracks very important, clean the stearing shaft very good and reseal it with high grade marine silicone.if it is cracked you can order a boot. ebay is where i found one for a Harley Davidson motor cycle but wasnt quite the same hole size so i used my old one.but to get as close as you can on the whole size measure the shaft size you have.
Also, I have taken the jet drive out to replace/check the oil ( any recommendations on oil type?)
Since I am this far into the removal figured I should just replace what I can , but I am new to all this.
I found a way to change and check the lower unit gear oil without taking the whole motor assembly out. I found a large head screw driver and heated it so i could bend it to a 45 deg angle and then got a new oil fill pump kit and heated it up and bent it also in a 45. its tight but works for me. the next thing i did is find a alan head drain plug on ebay also. It is coming in the mail now, this will solve the bending the screw driver, just use a allen wrench. You will have to take off the scoop and trim plate of course but way better than pulling the whole motor.Takes me about 30 mins to change the oil now with air tools. the owners manual calls for SAE 90 for the jet pump..i use Pennzoil or mercury for my stuff can find it at walmart. i just got these and havnt put them on yet so not even sure if they fit. if so they will solve the oil fill/drain problem.
Lower Unit Drain Plug Screw Evinrude E-Tec Outboard 18-4255 307551 Allen Head
I see some play in the shafts ,
I also cannot seem to remove cover on the vertical shaft that goes thought it .... any tips?
no idea on this i lucked out my whole engine and jet drive system was brand new NOS.
Turning the shaft I hear some minor grinding but I am not sure if its a bearing, should I just replace them anyways since I am a this point, removal tips appreciated?
being your this far into it take all the bearings out and take them to the parts store and get new ones
FYI....I did have some leaks around the gasket that bolts the engine to the frame, i cleaned it good with carb cleaner and break cleaner and blew it dry with air (top and bottom) and brushed on some liquid seal in the can with a paint brush, (problem solved) no leaks so far with 4 trips out. key here on all of this stuff is clean no grease nothing.
There is only one guy in America that i know of that has any parts for this boat and his name is John at American Jetboard 262 203 3005. you need deeeeeep pockets.John can tell you anything you want to know about this boat he has restored dozens he said.
hope this helps most of the guys on here are long gone but ill try to help if i can. Tom in Georgia
see pics attached for references..
I`ll try to get some pictures of what i did and post them.
Any help appreciated.
View attachment 116966View attachment 116967View attachment 116967View attachment 116969View attachment 116978View attachment 116968View attachment 116969View attachment 116970View attachment 116971View attachment 116972View attachment 116973View attachment 116974View attachment 116975View attachment 116976View attachment 116977
