ultranautics jet star 1250 innfo
Thank you. I took the whole lower jet apart and sealed up all of the screws going into the hull. Still leaks. Maybe the water lines? It's coming from the corner of the engine where the water lines are. And I'm getting a lot of water in the hull. Steering boot is also good.
yes it could be the lines but theres only a couple so go on a replace them to be safe. i never had a leak on my lines just around the engine gasket, but had them in other places. best thing to do is make sure all the water is gone from the hull and take off the covers and doors and put it in the water it was still hooked to the trailer but in water enough to float it.get a flash lite and look around.
good luck
i looked at the parts book. the part is a grease seal. ours doesnt have one so trying to figure out how to make one or if there is another brand of one.
also i am getting a new wear ring and havnt figured out how to take off the old wear ring. ? how did you get yours off?
Please! I need a new wear ring for my ultranautics jet star 1250 suzuki 50 hp thanks kjell
good luck
How hard is it to replace the engine gasket and where do I get one ? Thank you.
try American Jetboard at (262) 203-3005 . They own the rights the the JetStar but last time i called in January was out.
also try
ok found his number Joe 616-502-5885 he builds the wear ring this is the only guy in the world i have found who is making them. and at a dam good price
which seal you used for the bottom unit? Sikaflex? Or other? Thank you :-)
Does anyone know the size of the bearing and oil seal that is in the end of the nozzle? They are both gone on my nozzle. It's the 1250 with the Suzuki motor.
