- Royal, AR
- SX
Anyone ever considered using a jet ski battery as the starter battery? I have every accessory in the boat hooked up to a deep cycle, only starters hooked up to starter. Its just two jet ski motors right? I do have a combine switch capability for emergency uses. Thoughts?
I have considered using a jet ski battery or an even smaller UPS AGM battery as an emergency starter battery. It does not take much to start our engines.
Do you have an ACR? If you have an ACR it would charge the small starting battery first then start charging the house battery. I think this is a good idea. It result in faster charges for your house battery.
I went with two group 31 batteries with a battery switch, a low voltage disconnect and an onboard shore power charger. I did not install an ACR because do not expect to run the engines enough to recharge the batteries on most outings. The LVD prevents draining the batteries far enough to prevent starting so I use both as house batteries.
