View attachment 19860 Those are the RGB controllers there. The fuse panel they are connected to run from the house batteries to the fuse panel. I had the radio running off the starter battery and had the hum, so I wired the stereo to the fuse panel as well and the hum was still there. Right now there is always a slight hum when I have the WS-420-SQ hooked up, when I take the 420 out of the equation, and hook the RCA's straight to the stereo, there is no hum noise when the stereo is on zero sound output, but as soon as I turn it to one, there is an audible hum. The hum doesn't get louder as I turn the stereo up from there. Also when I turn the RGBs on when the RCA's are hooked to the stereo, the Hum doesn't get louder like it does when I use the 420.
Considerations I have thought:
While I did run a small jumper ground wire from a ground on the starter battery circuit to the house battery circuit, I am going to try to ground the radio directly to the fuse panel on the house side.
I could have the amp gains up too much on the tower speakers. The speakers never distort at the level they are at now, but I have it turned up about 75 percent of the way.
I ran 14 AWG power and ground around the front of the boat along the same route as I did the RCA's, maybe that is causing some interference?
