I have done this on jetskis that rust through the manifolds. As long as its a real good epoxy that can take heat it will be fineNo concern that it can’t pop out in the future being permanently epoxied?
The purpose of the plug is to block off the hole used to empty out the "sand" or whatever is used when they cast the part@Julian - can we ask our contacts at Yamaha what the purpose of this plug is for ? it's not mentioned in my shop manual and especially since it's at different locations on the MR1 vs. 1.8l motors and that in 10+ years with yamaha's I've not heard of another member loosing this part,
I would normally believe you without question but....The purpose of the plug is to block off the hole used to empty out the "sand" or whatever is used when they cast the part
Yours is an mr1 his is a 1.8 totally different animals but anything cast has to have a way to get filler material out. Now whether they plug the hole or weld over it like brp does is up to the manufacturer. The material has to come out somewhereI would normally believe you without question but....
my "plug" is on an entirely different piece than his ??? should every cast piece have this plug ?
So conclusion to the questions of what this is for is just for getting the sand out of the mold. It has no use that correlated to he motor running other than plugging g the hole?
I put one back in it with loctite on it. Let it sit for 45 mins. Hose testing it the plug stays in but when I put my finger on it there is a small amount of water coming through just enough for the temp of my finger to be damp.
I did rev it a few times in the hose and see if it would shoot the plug out. Up to even 7000 rpms and it didn’t.
granted water pressure is not the same on the hose.
If this is has no use then my next step I think will be trying to epoxy the whole thing in.
I’m debating if I should take it down to the lake to run it and pop the plug out so I can epoxy all of it. Or if I should just epoxy over it the way it currently is?
So my "freeze" plug is on the top of the uppermost fitting in the exhaust systemThey are there for casting but they have the name FREEZE plug because if your motor has water in the cooling passages and freezes hard they should pop out and keep from cracking or warping your engine/head/manifold.
If you have no worry of that ever happening then epoxy away.
Inspection port? Is it the size of a 3/8 ratchet?
I guess it should theoretically still blow open like a beer cap in the freezer. I don’t know how effective they always are.So my "freeze" plug is on the top of the uppermost fitting in the exhaust system
Being in position it would still protect for freezing??
