MrMoose
- Calgary, AB, Canada
As an ex-quality engineer, it comes down to weighing the impact of failure against the expected failure rate and the cost of preventing the failure from happening (i.e. preventive maintenance). Considering that an impeller duct bearing failure can be really expensive to fix, can strand you if you only have one engine, and can ruin your vacation, pulling the cone and checking for water annually seems to be a reasonable thing to do.
The unknown in all of this is the expected failure rate, but it is important to consider that it is likely similar to that of a prop shaft... and the prop industry checks for water ingress annually.
As an aside, it's much easier to grease the pivot points (nozzle, gate, steering) when they are disassembled, which is required in order to remove the cone.
