Recently I discovered that the DVSR does not look at the start and house batteries separately, the DVSR looks at the both the start and house batteries for its close voltage signal of 13.4VDC. In other words, if the DVSR detects what it thinks is charging voltage the relay will close the positive contact and parallel the start and house batteries.
The start battery cables are connected to the engines, so by virtue of how the engine battery cables are connected to the start battery means the start battery charges first since it is connected to the charging system, thereby raising the voltage the DVSR sees to 13.4VDC, then the relay closes the contact paralleling the start and house batteries.
I discovered this when I upgraded my house battery to a Battle Born 100AhLiFePO, the resting voltage of a fully charged LiFePO battery is 13.6VDC. When I connected the LiFePO battery the DVSR closed and started “charging” the AGM start battery. I had to cut the red wire on the back of the DVSR and hooked it up to a switched ckt so that the operating power source for the DVSR is now manually controlled. After starting main engines I wait for the AGM start battery to either be equal to or greater than the house LiFePO battery then switch on the operating power to the DVSR for it to parallel the batteries, then turn the switch off when I stop. In the near future the DVSR operating power will get its source / operating power via an ignition hot that passes through a time delay relay with a 300 second delay to allow the voltage on the AGM start battery voltage to be > or = to the LiFePO house battery before paralleling so that the electron flow will be towards the house battery.
The issue I have with the connext battery voltages is that they read .4 volts low on both batteries. The battery levels do change, ergo the house battery voltage (in the past with a flooded acid battery) will drop well below the start battery after many hours on the water with the fish finder and live well running while the start battery voltage is stable.
So it appears that the issue with the SPU having continuity may have been solved on my 2020 model year boat.
My question is, what is causing both batteries to read low by .4 volts respectively on the connext screen
@Mainah ? My friend suggested it might be a zener diode used in the system that is causing this, could it be a zener diode in the SPU?
I had thought initially that my 30 year old Fluke 77 meters’ calibration may have drifted a bit, but I took it to an electronics store and checked it against one of the stores meters and against my friends much younger Fluke meter and my meter was spot on with those meters.
