Huge Power Loss
It does happen. Rebuilds are done locally quite a bit. I bet even some motorcycle shops could take the MR-1s with some of the similarities to the R-1 motorcycle engine. Think of the variety of engines the small lawn places have to see...but many of those are also booked months in advance. It seems a hard business to make money on, since so few do it, but they can be found here and there.
Unfortunately this isn’t that isolated of an incident, and an unsupported shaft can lead to crank bearing failure if not addressed.
This happens in skis sometimes from what I’ve read, and Riva even sells a replacement sleeve for the crank case to fix the problem in some cases (which still requires a machine shop).
For me, the cost just to get the whole thing diagnosed was ridiculous, and when a local mechanic gave me some figures on repair, it seemed that a replacement would be just as cost effective.
Good information @AboveTheBest
You've got significantly more patience than I do. Let me know when you go to drop the newest motor back in and I'll drive up and lend a hand. Would love to learn a thing or two about how these come in/out boats. I'll buy pizza/beer!
That’s a deal
The motor showed up yesterday and I put it in today!
I just need to fill it with 10W40 and hope tomorrow’s sea-trial goes better than the last two...
105508
Wow!!!
I can not imagine doing something like that... in a day. Very impressive. Hope this goes well!!
The transplant was a success :)
The new engine runs great!
It took a few minutes of working the 15-month old gas out of the lines, but after that it felt like a new boat.
I did get an update on the old engine as well. The assumption was correct, the crank case was trashed. I was told there was nothing left that was useable, and the mechanic was pretty impressed that the engine kept going long enough to cause that much damage.
After the pump bearings failed it allowed the shaft to move laterally, which caused it to bang on the crank and knock it out of alignment.
Moral of the story; loud noises coming from the pump section are bad, and if left untreated could lead to pump failure and eventual catastrophic engine failure.
1. Emergency Engine Shutdown
2. Land as Soon as Possible
Now time to sell the boat.
My 2019 has rattled from day one. I'm always inspecting the wear ring. I'm hoping if/when something does go wrong I will detect it over this already noisy boat. The nice thing about these boats is you replace an engine and you have a new boat. With the I/O's there is still a long list of expensive mechanical wear items.
Glad to see a successful transplant.
Moral of the story; loud noises coming from the pump section are bad.
Tremendous news! Congratulations.
And one of the most important PSAs for all the Yamaha boats out there.
Thank you for sharing the saga. So glad it ends well!!!!
I am so sorry you had to go through all of that. The information from the experience is really appreciated. Thank you for all the time you took to share great details. I now have two reasons I will not slalom behind my boat. 1. I will break myself. 2. I will break my boat.
