AboveTheBest
- Bloomington, IN
- Limited S
@boudin, the shaft was etched out a little, but the wave runner shop said they were able to salvage it. I’m hopeful that isn’t the case because a new shaft = redoing the bearings again...
@swatski, the gap between my impeller and pump is like the one in the picture, so I don’t think that’s the problem.
I just put everything back in the boat and fired it up in the driveway. I also took a Sharpie and marked on the inside of the housings to see if this is where the binding was occurring.
The boat started up, with no “clunks” or other noises initially, but then started making a bit of a racket back by the transom. It didn’t sound like engine noise, but something was definitely banging around, but not necessarily in perfect time with the RPM’s.
I took the pump back off and found all of the Sharpie was still intact, meaning the impeller isn’t grinding.
I also know the engine doesn’t make any noise with the pump off, so that leaves whatever is in-between (intermediate shaft/bearing).
I’m not seeing any torn up rubber under the bearing, but it did seem a little bit like there was some grease on the mid-shaft.
I’m guessing the problem is the female end of the shaft is stripped or the bearing is toast. I’m really not looking forward to moving the engine to pull the mid shaft (and I don’t know how to take it out anyway), so there’s about a 75% chance it’s going to the shop tomorrow.
While I hate to pay shop fees, I also hate working on the boat when it’s 90 degrees out, and I want this done yesterday so I can finally get back on the water!
ETA: Wow, 6-pages in this thread... this is turning into a novel.
