Dean P
- Florida
- Chaparral
- VRX
Here's my attempt at DIY Anchor Stick Pins. Heard about the stick pin from this forum which gave me the motivation to do something. The conduit I had lying around the house and thought that might work.
Took 2-1/2" plastic conduit, cut 16" long (from the bell end), heated the inside all around about 5" up and stood on a brick to flatten it out until cool. Cut a 1/2 wide slot x 2-1/2" long in the flat end and drilled 1" hole thru bell end (keyhole saw). Placed onto U-bolts (upside down to create tension) and wedged PVC to hold in place. Purchased some (4 for 20$) 8 ft long x 3/4 (actually measure Ø.805") fiberglass garden/tree stakes from Walmart and pushed them thru the 1" hole into the ground below. The tide was high, slowly going out and about 3-1/2 ft deep (at the back end of the boat)
I pulled up closed to the seawall and placed the first stick pin into the port side holder. As the boat swung around I placed the other stick pin in and waited. The boat was perpendicular to the wind which was blowing at 10 mph with gust up to 14. I was very impressed with how well it did. The boat did sway a little but always came back to center. Below are a few pics of what it looked like. The boat stayed in that spot for well over 1-1/2 hours.
This is still a work in progress but so far am please with the results. Need to attach a T handle or a (bicycle type) grip handle. Haven't decided...
Here is a 2 minute video of it in action.
