The official "What did you do to your jet boat today" thread.
Before and after. Not perfect but better.
looks good from my house! I can kinda see the faded spot from the old unit, is that what you're referring to? Would it be worth it to silicone around that with a tool to get a nice consistent bead? Might cover some of the discoloration, and those tools are super cheap. For small stuff likek that, I use some tool that has a ball on th end, and the excess is just peeled off afterwards, but you're left with a perfect consistent bead that looks really nice. I'll try to track down alink later.
Yep. Plenty of room. It is annoying leaning over and working on my knees. The hardest part was finding all the hidden bolts for the oil pump, then scraping old gasket off. I was able to use my 1/4” driver to remove the flywheel bolt (it IS reverse thread). My 1/2” impact was too big. Surprisingly the small driver had enough “uumph” to break it free
For future use, @FSH 210 Sport made a platform to help with working over the engines. He may have a link to it in his sginature, but if not, this will tage him and he'll definitely be able to find it for you. Definitely a useful thing to build
I put on labels over the buttons.
Ask and you shall receive ! Put your hands on the radio say Hallelujah Brother !
That’s freakin genius! Definitely building one of my own!
Took it out for last outing of 2024! Wow 80 degrees in Maryland in November!
Cut a big hole in my boat...
It worked out OK, but man was there a lot of fiberglass dust to clean out.
Something that may help in the future when cutting holes in fiberglass, get a helper to hold a shop vac hose right next to the bit doing the cutting, this is very helpful at controlling the spoil from the cut. Another thing that helps is to use as fine toothed cutting tool, this keeps serves two purposes, it reduces spalling, produces a smoother edge and the cuttings don’t want to fling as far.
Dremel circle cutter gets it done!:thumbsup:
Got our oil change kits yesterday, since they were on sale, although the boat is still in storage for a few more months. Yesterday we paid off the AR230, 6 years early, which is a good feeling. I assume now is about the time something will go wrong this upcoming season since the bank no longer owns it 🤣
After installing a LiFePO4 house battery a year ago I finally got around to adding a proper battery box as the Group 31 battery did not fit in the bettery well so It was one end inside and the other end out sitting on an angle. I also replaced my generic Amazon shunt with a Victron SmartShunt with a DIY ground Bus Bar.
For the battery box I used (2) 1" HDPE screed together to give me 2" block and mounted to the bottom of the battery box. Used 2 AWG cable to run from the battery to the shunt and the buss bar is 1/4" x 3/4" copper bar.
Before Photos
After Photos
After installing a LiFePO4 house battery a year ago I finally got around to adding a proper battery box as the Group 31 batter did not fit in the bettery well so It was one end inside and the other end out sitting on an angle. I also replaced my generic Amazon shunt with a Victron SmartShunt with a DIY ground Bus Bar.
Before Photos
View attachment 231046View attachment 231047
After Photos
View attachment 231048View attachment 231049View attachment 231050
Clean!!!
